palmeri8145
Newbie
Message 21 of 22
Re: Picture Stutters on Freeview and the additional channels unless I remove and reinsert the HDMI c
Hi all - I've been reporting this error on the sony forums since I bought the TV last October 2015 and moved to BT from Sky. however, it seems to me that the issue is Sony and not BT.
I have 49X8309 and the BT Ultra box.
Periodically and randomly, the picture statrs to judder / jitter. The only way to resolve is to switch the tv off / on. This seems to "resync" the tv again. Switching the BT box off / on doesn't help.
It seems to be slightly better since a Feb 2016 upgrade but still occurs multiple times per week on all channels (SD/HD/4K).
Moderator
Moderator
Message 22 of 22
Hi Users
Good News for anyone experiencing a problem with picture judder on their Sony UHD TV's. Sony have now put a fix in place for this and you can find more information on this link
http://www.sony.co.uk/support/en/content/cnt-hn/prd-tvhc/Juddering-issue-on-4K-TVs-with-UHD-STB-UPDA...
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
