KernowChris
Expert
Message 11 of 22
Re: Picture Stutters on Freeview and the additional channels unless I remove and reinsert the HDMI c
Hi SeanD,
Worked ok for most of the week following the update, have set box to UHD again since Thurs, sadly tonight the problem has recurred, whilst on BBC ONE HD. Maybe you can pass this observation on to the team as more evidence in their discussions with Sony.
Community Manager
Community Manager
Message 12 of 22
Hi @KernowChris
Thanks for letting me know and I will certainly pass this on to YouView.  Very disappointing I am sure Smiley Sad
Community ManagerSeanD
Show your appreciation!
Kudos”Kudos”
KernowChris
Expert
Message 13 of 22
Is there any news from YouView/BT/Sony on this issue? Had to go through a full reset routine before MCY-PSG this evening, the judder was back with avengance.
Telecom89
Recognised Expert
Message 14 of 22
Does turning off Sony's motionflow help?
KernowChris
Expert
Message 15 of 22
No, it manifests itself with sporadic tearing of the screen.
Community Manager
Community Manager
Message 16 of 22
Hi @KernowChris,
I will see what I can find out.  Very disappointing that this issue is back with a vengeance after what appeared to be an improvement Smiley Sad
I will get back to you as soon as I get an update.
Cheers
Sean
Kudos”Kudos”
patelc7
Message 17 of 22
FYI this is a Sony issue.
I have had a fault logged with Sony since last June.  I am on my third
 Sony TV since then and they are about to swap it again.
they have admitted to me it's their issue, but they are very poor in telling their customers.
the TV I have is the 9305c 65 inch.  I saw it on the same model 55inch one as well.
it's not just with the Yoiview stb, it's been seen when running Netflix from the tv.
 Sony have been very poor.
patelc7
Message 18 of 22
new Sony update today so that may solve it
Tags (1)
royce8
Message 19 of 22
Hi,can you tell me what is exactly going wrong with the sony (x93c) televisions ? thanks
royce8
Message 20 of 22
Hello patelc7, what are sony saying about the stuttering problem you are getting ? is it something in one of the microchips that's causing the stutter picture ?
