xninian
Message 1 of 3
Picture stretched vertically
Was watching a recording (good picture) and suddenly picture stretched vertically.  Now everything (including live broadcasts) is stretched.  Using HDMI 1080p as have done since Humax box received.  Have reset the box following instructions and still problem exists, but so far have kept all recordings.
Noted that box received the latest software on the 18th (ie today and before i did the reset).
Noticed that scheduled recordings hav disappeared although all my saved recordings are there
Anyone else had this?  A good time of year to get the box go down!
Checked the obvious things so far, but obviously suggestions are welcome
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Picture stretched vertically
Hi xninian,
Thanks for posting. Sorry you're having problems. Can you try connecting using a scart cable and let us know if that helps?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
xninian
Message 3 of 3
David - Many thanks for your interest.
After a lot of checking I managed to retrieve everything yesterday.  I have absolutely no idea what was the initial cause.  With some discussion with my son part of whose job is to deal with problems like this it seems that seversl events happened at the same time - main indications were that all scheduled recordings were lost (before I did the V+ box reinstall, which I had to do twice) and also settings in the TV had changed.  Can only surmise that the HDMI connection must have been the carrier that transmitted the problem between the two.
As I have said I have still got no idea as to the root cause and anything else I could say would be pure speculation.
