Htfc1
Message 1 of 21
Pixelation
Youview picture keeps pixelating. Router keeps disconnecting while watching tv on youview box. No problems found at bt end.
20 REPLIES 20
B13blues
Message 2 of 21
Re: Pixelation
Would try an aerial signal booster or an attenuator if you've been through the turning everything off/on routine. Both are cheap.
B13blues
Message 3 of 21
Re: Pixelation
Sorry never noticed you said router was disconnecting so they won't help
Moderator
Moderator
Message 4 of 21
Re: Pixelation
Hi @Htfc1,
Thanks for your post and welcome back!
Sorry that you're seeing pixelation whilst watching BT TV.  Have a look at our help pages here >> Channel problems on BT TV <<
Post back and let us know how you get on with this.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
TimCurtis
Recognised Expert
Message 5 of 21
Re: Pixelation
Are you referring specifically to the BT TV internet channels or the normal Freeview channels like BBC1 or ITV?
Htfc1
Message 6 of 21
Re: Pixelation
Hi
Freeview channels are fine.
TimCurtis
Recognised Expert
Message 7 of 21
Re: Pixelation
@Htfc1
How is the Youview box connected to the router, direct ethernet cable or power line adapters (PLAs)?
Are you also able to post your connection stats from the HomeHub , showing the downstream/Upstream speeds, noise margin etc?
Also try a quiet line test , preferably with a corded phone , dial 17070 & option 2. If there's ANY noise then report that as a phone line problem. Noise on the line can at times seriously affect the router's ability to maintain a connection.
Htfc1
Message 8 of 21
Re: Pixelation
Hi Tim
Youview box is connected by ethernet cable to router.
Crackling on line but bt say there is no problem with line.?
Speed to hub - Download 19mb
Upload 0.4mb
Speed to device- Download 16mb
Upload 0.4mb
Message 9 of 21
Re: Pixelation
The line should be totally quiet. Cracking on the line will introduce errors, which is why you are seeing the problem. Multicast is not very tolerant of line errors.
Report a noisy phone line. Once that is fixed, and the line is quiet, the problem should go away.
The BT line test cannot show this type of fault.
Htfc1
Message 10 of 21
Re: Pixelation
Hi
The pixelation was really bad last night when it was windy, most of the time its the connection dropping which can happen at anytime.
Regards Mick
