Message 11 of 21
Re: Pixelation
@Htfc1 wrote:
Hi
The pixelation was really bad last night when it was windy, most of the time its the connection dropping which can happen at anytime.
Regards Mick
Then there is a bad connection somewhere on the external network. If you are fed overhead from a pole, then it could be a fault on the dropwire, or the associated connections.
Report the line fault, and  hopefully it will be fixed. Any problems, please post back here.
Once it has been fixed, and your picture is clear, then please update this thread. Thanks.
Moderator
Moderator
Message 12 of 21
Re: Pixelation
@Htfc1 if you need any help with this please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Htfc1
Message 13 of 21
Re: Pixelation
Hi
Kept loseing internet connection all night. Now solid orange light on hub. Will this ever be fixed.
Message 14 of 21
Re: Pixelation
Did you contact @NeilO as requested?
Moderator
Moderator
Message 15 of 21
Re: Pixelation
Hi @Htfc1 sorry you are still experiencing a problem with your Internet BTTV channels. I've checked and cannot find a completed form from you. Please can you complete the form on the link offered by @NeilO above and we will be happy to help you with this.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Moderator
Moderator
Message 16 of 21
Re: Pixelation
@Htfc1 I called there but missed you, I'll send you an email with an update.
Kudos”Kudos”
Htfc1
Message 17 of 21
Re: Pixelation
Hi Neil
They rung up and cancelled the engineer saying they had found a fault. We are still getting disconnected all the time so the fault isnt fixed.
Mick
Moderator
Moderator
Message 18 of 21
Re: Pixelation
Hi @Htfc1
Thanks for the update.
@NeilO is dealing with your case and he has sent you an email.  You can get in touch with Neil by replying to his email.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
Moderator
Moderator
Message 19 of 21
Re: Pixelation
@Htfc1 many thanks for confirming the engineer managed to get this sorted for you on Friday. If you need any help in the future post back and we'll be happy to assist.
Merry Christmas and have a happy new year
Neil
Kudos”Kudos”
ByeToSky
Message 20 of 21
Re: Pixelation
Hi,
Sounds like your YouView box is fine. However your router, router link or ISP service is not.
Can you give details of your Broadband provider and the router you are using.
Have you tested out your neighbours Wi-Fi bands and strengths?
Do you also have Sky Q? If so do you have a problematic mini box?
How many other devices share your bandwidth? Does the problem coincide with other device use?
Have you tested your link speed for the router when you are getting pixalation?
Is your TV link from your router via powerline units. Have you run diagnostics (App) on the powerline units?
If powerline, are the units on seperate ring mains. If powerline what is the make of the powerline units?
Is your master phone socket old. Does it have an product code? Is your router connected to the master socket?
What model master socket do you have. Does your phone line have noise on the line?
Be regards, ByeToSky
