GarryJ
Message 1 of 5
Placing online order for extra box subscription
I started to go through an online order for extra box, just to see what would happen and would i be charged for another box (which i do not need as i have 2), was given the option for a £49 box, a £99 one or subscription only, i went for the latter, do need new broadband extenders @ £20, then the £5 charge monthly for the extra service, all seemed to go through okay, got to the last page to confirm order, which is when i cancelled as i was just trying it out, was wondering if the above means the order would have gone through and would i have been asked to buy another box earlier in the order?
Moderator
Moderator
Message 2 of 5
Re: Placing online order for extra box subscription
Hi @GarryJ
Thanks for your post and welcome back!  I have moved your post to start your own thread as that's the best thing to do.
Apologies for the confusion.  If you didn't complete the order then it doesn't sound like it went through.  Did it ask for an email address when going through the order online?
When an order is successfully placed we would send an order confirmation email so if you haven't received one we can safely say the order didn't go through.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
GarryJ
Message 3 of 5
Thanks for the quick reply, no, i cancelled the order myself, i was just trying to see, as i already have 2 BT boxes, 1 of which was not supplied by BT i must add, a "zapper" box, if an order would go through without being forced to buy another box that i do not need, i went through with everything, and the new broadband extenders, and got to the final page asking me to confirm order, it was at that point, i myself cancelled, so was wondering, does it look like the order would have gone through without the need to buy another box?
Moderator
Moderator
Message 4 of 5
@GarryJ My understanding of the online order journey is that you wouldn't be forced to get another box if you didn't need one. If it wasn't listed in the order details it sounds like a box wasn't added.
If you need any help with placing an order use the contact the mods link to send over your details and we'll be happy to help. You'll see the link if you click my username.
Community ModeratorNeilO
Kudos”
GarryJ
Message 5 of 5
Thanks for the reply NeilO, yes it does look like i am not forced into buying another box through online ordering, will make my mind up on if i am going to go ahead with this over the next few days, thanks again for all your help with this matter.
