Danfoster20
Message 1 of 5
Players not working HELP!!
Hi. BT player and none of the BBC or ITV or other players are working. The Netflix player works fine. When I go to open one of them it says ‘loading’ for a brief second and then clicks back to the main menu. I’ve reset my hub and reset my box. I’m really really trying to avoid a factory reset of my box as I have loads of recordings I want to keep. I have checked the software and all upto date. I have retuned channels just incase. None has worked. Please help...
4 REPLIES 4
BiggMatt187
Message 2 of 5
Re: Players not working HELP!!
It will reset anyway after a while as they all do... like ours has just after xmas and 3 times before.... just do it and see if it helps.. if it doesnt then there is always the ombudsman.. got to ofcom.... not the other one.. its obviously bent
zulu17
Distinguished Guru
Distinguished Guru
Message 3 of 5
@Danfoster20 wlcome to the forum.
Can i clarify when you say you have reset your Youview box  what precisely you have tried  as there are many reset options .
if you have a look at
https://community.youview.com/youview/discussion/6251537/top-tip-soft-reset-reboot-power-cycling-mai...
which of those options have you done thusfar.
Also which Youview box do you have Youview > Settings > Device information  will give the model number if you are unsure.
Also if on the Youview box  go Youview > Settings > Software Information  - what is the manufacture software value   and do the Last checked for players & apps sho a recent date.   (on that screen may be worth trying the Update players and apps option)_.
Also roughly what is your broadband speed ?
Are you using a VPN at all ?
Danfoster20
Message 4 of 5
Humax DTRT4000 Variant 87B08500 is the device information. Manufacturer software is: 29.36.0 and software update checks were last done today. The box reset that I did was turning it off at the plug. Waiting about a minute and then turning it on again.
Broadband speed is 50mbps ish and no VPN use.
Is there anything else I can do? Thanks in advance.
Danfoster20
Message 5 of 5
Maintenance mode fixed it a treat!! Thank you!!!
