Murviman
Message 1 of 4
Poor sound from YouView box
Having read through others experience I am aware mine is not an uncommon problem. The problem has become an issue fairly recently showing itself as if spooling the sound. It normally takes a while to develop and then becomes more and more prevalent until a real pain and too intrusive to continue. I have switched the box off and given it an opportunity to restart cleanly but was unsuccessful. Picture is fine and broadband speed is excellent. Am I right in thinking a replacement box is the way forward or are there options I’ve missed? Any guidance gratefully received.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Poor sound from YouView box
Hi @Murviman sorry you are experiencing a problem with the sound on your BTTV service.
Have you checked that your software is updated to the latest version on the box. Also a reset of your box may resolve the issue check out How do I reset my BT TV box? for information on how to do this.
Post back and let me know how you get on.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Murviman
Message 3 of 4
Thanks for your input, John.
I had already reset the box and checked for latest software, with no change. My delay in responding is due to the problem mysteriously disappearing and my wanting to see if it came back after a short while. To date all is good. Why is a mystery.
Moderator
Moderator
Message 4 of 4
Hi @Murviman Thanks for the update and should the problem happen again drop back and let us know.
Cheers
John
Kudos”
