jparnell82
Expert
Message 1 of 3
Popup BT TV advert just appeared over the screen
Hello,
Just turned on my youview box and a BT TV popup appeared over the screen with a promotion to get Tarzan for free on BT TV.i had option to close or redeem.
Has anyone else seen this?! It's the first time I've seen it.
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Popup BT TV advert just appeared over the screen
DanielS
Moderator
Moderator
Message 3 of 3
Hi @jparnell82,
If you follow the link @Keith_Beddoe you will see a post from @-Richie-. His post gives you the direct link to log in and choose the HD or SD option. I chose the HD option to test and it's working perfect.
Enjoy
DanielS
