jam2000
Expert
Message 1 of 3
Power line adapters
So do these work for the Extra channels and BT Sport on BT Infinity?
I am looking at the 500Mpbs ones, would I be able to stream/record two channels at once using these?
Anyone use any good ones which they could suggest?
I am currently looking at the Trendnet ones which offer speeds up to 500Mpbs
2 REPLIES 2
Message 2 of 3
Re: Power line adapters
Hiya,
not 100% but do check if they can cope with Multicast transmissions, i have the standard powerlines provided by BT and seem to be ok.
cheers
CG Over An Out
TimCurtis
Recognised Expert
Message 3 of 3
I've used both Netgear & TP-Link powerline adapters - the Netgears were AV200 - and had no issues streaming at all.
Anything AV200 or better should handle 100mbps with ease.
