CrazyNutter
Message 1 of 12
Powerline adapters
Hello
i want to order Uview for my bedroom but my router is downstairs in the living room so i will be needing some  Powerline adapters, my question is do i need to buy these or will i get some with it?
thank you
11 REPLIES 11
Liam4503
Message 2 of 12
Re: Powerline adapters
Hi
Just ordered and received my youview box. I requested the adapters when ordering and they were delivered with the box at no extra cost.
Quick and easy to set up, Ethernet cables included. Works perfectly.
CrazyNutter
Message 3 of 12
cool thanks, i cant order til my broadand order is marked...
cool thanks, i cant order til my broadand order is marked as completed tomorrow lol
kryten22uk
Message 4 of 12
Re: cool thanks, i cant order til my broadand order is marked...
Bear in mind that it happens in a round-about way rather than directly asking if you want adapters.  They simply ask if your box will be more than a certain distance from the router.  If you click Yes, then you'll get free adapters.  If you click No, then you wont.
CrazyNutter
Message 5 of 12
im having problems ordering it now lol iv just tried and its saying my line is to slow yet a line test says im getting 16-17mbs?
CrazyNutter
Message 6 of 12
just for anyone else with this probem i rang customer services about it and they say there is a fault on the systems and they are fixing it within the next 48 hours 🙂
notoriousdbp
Recognised Expert
Message 7 of 12
If you ring sales you can often get a better deal. Also bear in mind that sometimes powerlines won't work from downstairs to upstairs as you can have separate circuits for each floor.
---Remember to mark as 'solved' and give stars when you like a post---
FollowMeChaps
Message 8 of 12
Can you clarify please - does this mean the powerline adaptors must be on the same ring circuit or is being on a common consumer box sufficient?
willc01
Message 9 of 12
yes the adapters must be on the same circuit/ fuse/MCB.  Occassionally they work but in most instances they dont.  I have had to run a seperate network cable from the bedroom to the router downstairs.
FollowMeChaps
Message 10 of 12
Many thanks.
