Steve21
Message 1 of 6
Powerline adaptors
Hi. Does anyone know if my t2110 youview box will work fine with a set of powerline adapters with a virgin superhub2ac (model vmdg490)router please? Chat help said powerline adapters will work fine,just wanted to double check.
Thanks in advance
5 REPLIES 5
Message 2 of 6
Re: Powerline adaptors
If you are with Virgin now, then you need to ask on their forum.
ruth554422
Expert
Message 3 of 6
No reason why they won't
TimCurtis
Recognised Expert
Message 4 of 6
Agreed, ISP or router not a factor.
varkanoid
Message 5 of 6
Also depends on the wiring in your house and where the hub is in reference to the BT youview box. If its on the same ring then it should work depending on age of your wiring. If its on different floors it should work however there are certain older master fuse boxes that dont allow the connection across different rings. I know I have one.
ruth554422
Expert
Message 6 of 6
That doesn't come into it if the user was already using power line adapters which the top post seams to indicate that they where already using them and double checking the powerline adapters will work with the new router which would indicate that the wiring is fine.
