JohnHatter
Message 1 of 10
Prime Video showing 5.1 but outputting Stereo
Got my new 2100 box today, set it up logged into Prime....cannot get 5.1 output though Film detail says it is there. Any ideas?  Thanks
9 REPLIES 9
JohnHatter
Message 2 of 10
Re: Amazon Prime Video App on our BT TV 4K UHD box
Hello, I received a new T2100 (non UHD) yesterday.  It shows Prime as 5.1 but only outputs Stereo. Is that the best I;m going to get from this box?
billybob99
Message 3 of 10
How is it connected, as if its direct to the tv then using arc to av amp your tv may recieve dd+ from the box but only send stero via arc
JohnHatter
Message 4 of 10
It’s into an Onkyo amp. Other 5.1 channels such as Syfy HD outputs 5.1 when it’s being broadcast
billybob99
Message 5 of 10
So output from bt box is direct to amp and then amp to tv using hdmi ?
JohnHatter
Message 6 of 10
billybob99
Message 7 of 10
Sorry, im out of ideas, I know there are issues with some online content being shown with DD+ apposed to DD which some tv's down converrt to stereo but if connected direct to amp not sure.
JohnHatter
Message 8 of 10
It’s disappointing, i didn’t expect 5.1 from Netflix, but Prime shows the 5.1 symbol. Maybe it’ll get fixed at some point. Thanks for getting involved 🙂
billybob99
Message 9 of 10
Netflix is the same for me through the bt box perfect 5.1 through the tv app though.
billybob99
Message 10 of 10
5.1 now seems to work fine, don't know if there has been an update but all good.
