mixstar
Message 11 of 11
Re: Problem with MyTV “Watched” after latest update.
Gary,
“ Also, on this point "Also, now when you go to delete a “watched” program you get the [Delete] & [Back] buttons whereas previously it deleted as soon as you hit delete on the remote without the choice." - it sounds like confirm delete is on in the settings you should be able to change that in the settings if you wish”
Fair enough but where is that setting? I can only find one similar in Settings> Recordings> Confirm Delete: yes/no which is nothing to do with this issue.
