sea2dog
Message 11 of 18
Re: Problems with Freeview channels cutting out
I can be watching a freeview HD channel 103 for example and go check it via the YouView box and it can drop signal for just over 7 seconds, prior to an engineer fitting an amplifier it wouldn't drop for as long as that but it will drop.
I now have 92 or 93% signal strength and 100% signal quality but like I say it can drop anytime so an amplifier isn't the answer and I too have the aerial in the loft.
sea2dog
Message 12 of 18
@LesC
Are you still experiencing the same issues?
LesC
Expert
Message 13 of 18
My problems turned out to be a faulty aerial amplifier. Must admit since changes to Sky Sports on BT (coupled with Freeview changes that meant no BBC news HD channel) I rarely use the BT box except for Champions League football...
sea2dog
Message 14 of 18
An engineer I had out recently fitted an antiference 75 series Digital Media IR Distribution Amplifier at the box end, it helped get the signal strength to 92% but I still get the occasional signal dropout, but its out for more seconds than previously prior to the amplifier installation.
I don't think my issue is fixed, as all these amplifiers do is magnify any reception issues.
sea2dog
Message 15 of 18
@LesC
Isn't channel 107 in HD for BBC NEWS?
LesC
Expert
Message 16 of 18
Unfortunately, don't get channel 107 in my area - Essex
TimCurtis
Recognised Expert
Message 17 of 18
@LesC
I'm in Essex (Benfleet) pointing to the Crystal Palace transmitter so get all the HD channels but I know other transmitters , mainly relay ones, are missing quite a few.
LesC
Expert
Message 18 of 18
Just checked on the Freeview site under 'what channels can I get' and it says I should get channel 107. I'm on the Crystal Palace transmitter too. However, just did a retune and it is still not found. Same with the TV too. I recall I lost the BBC News HD channel last time there was a retune...
