HighleyAndy
Message 1 of 2
Problems with Humax dtrt4000 YouView box
Hi,
A few weeks ago I had a new 4k set top box installed as a replacement for an older model (i think the new one is a Humax dtrt4000). The box continually seems to go in to a 'deep sleep' and will not turn on with the remote control. The only way to get it to turn on is to disconnect completely from the power supply, wait a few seconds, and then reconnect and switch on at the back of the box. Even then this can take several attempts. I have reset the box to factory settings a number of times to try to clear the problem, but this seems to make no difference. Occassionally the box will also just switch off while I am watching a programme. This is now getting very frustrating as I never had problems with the older box. Any ideas very welcome.
1 REPLY 1
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Problems with Humax dtrt4000 YouView box
Hi @HighleyAndy
Probably best to report the fault  on 150 or 0800 800 150.
I assume the box is positioned in a reasonably ventilated place and  not overheating?
