kipper1954
Message 11 of 14
Re: Problems with Now TV buffering through BT TV
Any news on an update for this problem?
Now TV still buffers on BT Youview.  No issues on Netflix and Prime
Martyboll
Message 12 of 14
Sorry, no idea. I stopped using the BT player and just use an Xbox to access NowTV.
kipper1954
Message 13 of 14
It doesn't seem right that it is BT I pay for Now TV, charged extra twice for the privilege of HD and it takes forever to sort, if at all. Both BT and Now TV should be interested in solving our issues.
Bluemoon1
Message 14 of 14
Hi
I am getting the spinning Now Tv logo freeze on my BT 4K box when watching catch up. The only way I found round it is to hit fast forward and play straight after and it seems to then play the rest of the episode.Also when exiting the NowTv app the Bt box goes to the last channel watched but blank screen and you can’t do anything until I do the reset button on the back.Which is annoying as I have to get up to do that 🤣. Bt Box connected via Ethernet cable all other apps work fine.
