kalamazoo
Message 1 of 8
Programme guide
When I access the guide it’s only showing programme details from bbc2 onwards. I have tried entering number 1 on the remote but that doesn’t work. So I can’t get in there to set up,any recordings. Any ideas please?
7 REPLIES 7
RobbieMac
Moderator
Moderator
Message 2 of 8
Re: Programme guide
Hi @kalamazoo
Thanks for your post and welcome back!  Apologies for the delay in a response to your post.
Is this still an issue? Definitely doesn't sound right to me.  If you're still having this problem post back and I will give you a hand from here.
Cheers,
Robbie
kalamazoo
Message 3 of 8
Re: Programme guide
Hi Robbie
yes it is still an issue. Easy to get round as I just use 101 for seeing what’s on and setting record. But the whole display appears a bit weird, not as crisp as it usually is. Just seemed strange that’s all. Thanks.
PaddyB
Moderator
Moderator
Message 4 of 8
Re: Programme guide
Hi @kalamazoo, Can you check you haven't hidden the channel from your TV guide by following these steps: Go to the TV guide, then press the YELLOW button on your remote, Enter your YouView PIN Press the RED button (not the red R button for recording) and this will restore any hidden channels. Thanks PaddyB
kalamazoo
Message 5 of 8
Re: Programme guide
Sorted! Thank you so much! I think I can pin it down to two small granddaughters who had hold of it the other day so in future the remote will go walkabouts! Much appreciated.
PaddyB
Moderator
Moderator
Message 6 of 8
Re: Programme guide
Hi @kalamazoo,
Thank you for taking the time to post back, I'm glad to hear the TV guide is back working as it should Smiley Happy
Cheers
PaddyB
gomezz
Recognised Expert
Message 7 of 8
Re: Programme guide
I thought channel editing / hiding needed the PIN?  Have you changed if from the default to something not easily, randomly guessed?
kalamazoo
Message 8 of 8
Re: Programme guide
Strangely enough when I followed the instructions given I didn’t need to enter the pin at all. I just got a shot of the guide with channel one there and it said hidden, so I deselected it and back it came. Glad it’s sorted anyway. Thanks.
