Hutch1
Message 1 of 2
Programming YouView remote control
I have just received a new remote control for my YouView box. When I try to program it to operate my Panasonic TV, after the blue light flashes 3 times it then comes back on and stays on. The only way to switch off the blue light is to press 'OK'. Can anyone suggest what I'm doing wrong?
1 REPLY 1
StewM
Distinguished Guru
Message 2 of 2
Re: Programming YouView remote control
High, I have a Panasonic TV and used this from the Youview Forum
Stew
