johnsy1968
Newbie
Message 1 of 5
Purple light
When I switch my box off, I get a purple light (blue & red at the same time) I'm not recording, just want to switch it off. In the morning I can only turn the box back on by unplugging the power, replugging & all is fine, but it's annoying...
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Purple light
You don't say which Youview+ box you have - if it is the newer one then a purple power light signifies that the box is in Standby (low economy) mode.
johnsy1968
Newbie
Message 3 of 5
Re: Purple light
It says BT youview DTRT2100
The purple is the blue & red on simaltainously, when it's on it won't record & it won't switch on, I have to remove the power laed
Message 4 of 5
Re: Purple light
I am experiencing the same issue with the same box. Stuck on purple standby light and unable to turn back on except by switching off and on from the power switch at the rear.
rarmitage124
Recognised Expert
Message 5 of 5
Re: Purple light
@Pedrocollins
Have a look here and see if it helps
https://community.youview.com/youview/topics/bt-youview-box-causing-issues-with-sony-tv
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
