Unless you have hidden it from your Youview guide previously .
The channel should appear in your Youview guide if you are able to receive channels from the relevent Freeview muliplex . Do you have the Drama Channel 20 or Paramount Channel 57 in your Youview guide as I believe they are provided on the same mux ?
