hicky56
Message 1 of 6
Re: 4od & 5 on demand not working on Youview box
Not working for me - do i need to open an new thread?
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
I moved your message to a new thread as you posted in a historic  solved thread last posted to a year ago.
Have you tried
  • power cycle: put the box in to standby, then turn it off completely at the back (or failing that the wall socket), wait about 20 seconds, now turn it back on and power it up.
If problems persist suggest posting back with more details
hicky56
Message 3 of 6
Hi,
Yes I've tried electrical fault repair 101 have you turned it off and on.  5od did work on friday week - and then hasnt since.
It shows the pre-show advert then sits there with black screen and the thing going around and  around and.....
hicky56
Message 4 of 6
Still got same problem 😞
Telecom89
Recognised Expert
Message 5 of 6
Try the following menu options:
YouView/Settings/Device Management/Software Update - then 'Get Update' - if that doesn't update software and get it working try:
YouView/Settings/Device Management/Update On Demand Players then 'Check Now'
I hope you get it working.
hicky56
Message 6 of 6
Cheers Telecom89 - software was the latest available, but the on demand player updated and ir now works ok. 🙂
I shall remember for next time.
