Thomasm5again
Message 1 of 2
Re: Box not recording
same thing - Humax 4k HD box lost scheduled recordings and 'record' button stopped working. Full reset fixed the problem.
1 REPLY 1
PaddyB
Moderator
Moderator
Message 2 of 2
Hi @Thomasm5again,
Thank you for posting. I'm sorry if you've had problems with the scheduled recordings not working. I've moved your post as that thread was over 3 years old.
I'm happy that the full reset has fixed the problem. Thank you for posting as that will be useful for anyone else that might have the same problem.
Thanks,
Paddy
