WillCo
Message 1 of 10
Re: Bt YouView+ sound issues
Our Internet TV is exactly the same ..... sound fades in and out, often multiple times a minute ..... driving me NUTS!  Been going on for a couple of months or so now.
I have turned off YouView box, checked all wires for good connectivity, turned YouView box back on and it's still there 😞
Ours is our original YouView box so we've had it a few years now - we're on Superfast broadband, have the latest router - ANY advice would be gratefully appreciated
Bill
9 REPLIES 9
WillCo
Message 2 of 10
We don't record Internet programmes and it's the Internet programme channels NOT Freeview we are having sound problems with.
As for loss of sound on Internet channels SD and HD the answer is yes
Moderator
Moderator
Message 3 of 10
@WillCo I've started your own thread as you're responding to questions directed at the OP who is experiencing a different problem.
How is your Youview box connected to the hub? Are you using powerline adapters?
WillCo
Message 4 of 10
they are sat side by side on the shelf connected by ethernet cable and we have no powerline adapters as it is plugged straight into the phone line which is 3 feet away from the box
WillCo
Message 5 of 10
and thank you for getting this thread separated, I was getting more than confused with all different answers coming in, I assumed I'd be talking to support?
JonGD
Message 6 of 10
Our box used to stutter on Internet channels (but fine when recorded). Updating the broadband connection in settings (edit connection, automatic) resolved it.
BT TV Expert
BT TV Expert
Message 7 of 10
Hi @WillCo
I'd like to take a look at this issue for you. Could you ping me your telephone number via a private message so I can get some checks done?
Thanks in advance,
David
WillCo
Message 8 of 10
Hi JonGD
Tried your suggestion but sadly no joy 😞
Moderator
Moderator
Message 9 of 10
Hi @WillCo Did you drop @David_H a Private Message and he will look into this further for you?
Cheers
John
WillCo
Message 10 of 10
Hi, yes I did, thanks 👍
