jmace86
Message 1 of 4
Re: Error message BTP 15000
Hi,
I am having the exact same problem with my new BT TV box.
I just phoned customer support and the guy I spoke to told me that there was some sort of glitch and that my broadband account was not linked to my BT TV account. He said he has passed it on to another team who can help with the issue but said it would take up to 72 hours. That means I am paying for a service I cannot use, which I think is pretty unacceptable.
Any chance of having this resolved a bit faster as seems to have been done for the user above?
3 REPLIES 3
BT TV Expert
BT TV Expert
Message 2 of 4
Hi @jmace86,
I have associated your TV account to your Broadband account.
Are you able to retest?
It may require a 'pin'hole' factory reset on your hub to force the change through.
Let me know if that helps or if you have any further problems.
Thank you,
jmace86
Message 3 of 4
Hi Gemma,
That worked perfectly.
thank you so much for the help!
BT TV Expert
BT TV Expert
Message 4 of 4
Hi @jmace86
Glad to hear all now working for you.
Thank you for confirming, and if you get any further issues, please let me know.
Thank you,
