Mocata1
Message 1 of 7
Re: Error message BTP 15000
I am having the same issues. Message comes up after every reset I've tried. To be honest the switch from Sky to BT has been a nightmare. It has been a constant to and fro to sort deliveries etc. Broadband and phone work fine now but my youview box is useless! I've tried phoning and online chat but they don't seem to know what I'm on about.
Can someone help?
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Welcome to this user forum.
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
Mocata1
Message 3 of 7
NeilO
Moderator
Moderator
Message 4 of 7
@Mocata1 Sorry about this, it sounds like there could be a problem with the subscription. Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Gemma_P
BT TV Expert
Message 5 of 7
Hi @Mocata1
I have made a configuration change on the account and the TV services should now be working.
You may need to do a factory reset on the hub to force the config change through.
Once that is done, please go to the BT Player, and then try the subscription channels. It may say 'You need to set up channels' just click 'OK' at that point.
If there is still an issue please let me know.
Thank you,
Mocata1
Message 6 of 7
Thank you, it worked without the reset. Thanks so much!
Gemma_P
BT TV Expert
Message 7 of 7
Hi @Mocata1
I'm glad this is now all working for you. Have a good day.
