Moderator
Moderator
Message 11 of 11
Re: Error message BTP-15990
Thanks for getting back and confirming that @DESIREESILVA .
Send over the details as per @JohnC2  request and we'll look into this for you.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
