hairychris
Message 1 of 3
Re: Help - bt sport error message IPC6007 after house move
I'm also having this problem. My YouView box works perfectly otherwise (I can watch most channels, and also box sets/catch-up TV etc) but am unable to watch BT Sport. I've tried the procedures suggested in the help pages.
Thanks in advance
2 REPLIES 2
Community Manager
Community Manager
Message 2 of 3
Re: BTP-20000
Hi @hairychris,
Welcome to the forum and I am sorry to hear you are experiencing this problem as well.  Unfortunately this isn't something that other members on the community will be able to help with so I will need to get your details.
Can you please drop me an email?  If you click on my username >>SeanD<< you will find the 'mods contact link' under the 'About me' section of my profile.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 3 of 3
Hi @hairychris,
Thanks for sending over your details. I ried calling you today, sorry I missed you. The reason you're having this problem is that you don't have a BT TV subscription so will need to sign up for one of our TV packs. You can find details at BT TV.
Cheers
David
Community ModeratorDaveM
Kudos”
