spain
Message 1 of 4
Re: IPC6023 error with Smart Hub 6
I have the same issue as a new customer, no internet channels on TV although I can receive them on mobile devices. Spent 2 hours with the call centre and have an engineer visit Tuesday but not convinced that will help as it is not a connection issue, more a software configuration problem with the you view box? Any other help appreciated! Beginning to think I should have stayed with Sky.
3 REPLIES 3
BT TV Expert
BT TV Expert
Message 2 of 4
Drop me a PM with your details and we'll fix it for you.
spain
Message 3 of 4
Many thanks for your help Steve, all working now
dowlandr
Message 4 of 4
Hi @Steve_M,
Are you able to explain what the solution was to this please?  I have recently just got a BT Smart Hub 6, and am getting the same problem.  I am able to watch the extra channels fine for just under 5 mins before the IPC6023 error appears.  I spoke to BT directly and they were unaware of any issue with the Hub 6 and so have sent out a replacement.  I get exactly the same issue on the replacement Hub 6.  My Hub 5 works absolutely fine with no issue...
Many thanks
Richard
