Message 11 of 33
Re: The Software Reset Problem
Why another 2 months wait if it's ready to go? It's a pretty critical bug!
Message 12 of 33
So, is this fix incorporated into 29.58.0? Going away in a couple of weeks, don't want another crash. Thanks.
BT TV Expert
Message 13 of 33
Currently 31.22.40
Message 14 of 33
Thanks, so that is still quite a few months away I take it?
Message 15 of 33
Anything that can be done? This is absolutely driving me nuts! I wouldn't mind if it was just me but I'm shielding my family's tech support calls to you by fixing this every time it happens.
BT TV Expert
Message 16 of 33
A couple of months @Niko1 yes, sorry! But we are delivering as soon as we can.
BT TV Expert
Message 17 of 33
Hi @Coffeehair,
Do you have the UHD 4K Youview box?
If so, a quick run down...Quite a few forum members already posted and we recovered their Youview boxes for testing. We then identified the cause of the problem and have a patch ready to be deployed in a future software release.
That software release we are targeting is currently 31.22.40 which is scheduled in a couple of months time.
If you do not have the UHD 4K Box, please PM me.
Message 18 of 33
Is there anything we can do to avoid it happening while we wait for the fix, i.e. leave in different stand-by mode? Thanks
BT TV Expert
Message 19 of 33
"Always ready" could do it @Niko1
I haven't tested this but the issue is detecting the Hard-drive.
If the Youview box was in an always ready state, it could avoid this.
Settings > Power > Change Standby Mode to Always Ready
Message 20 of 33
Many thanks, will try it..
