Niko1
Message 21 of 32
Re: The Software Reset Problem
Any fixed date for 31.22.40? Should be in a couple of weeks time shouldn't it?
BT TV Expert
BT TV Expert
Message 22 of 32
Update
The fix did not make it into 31.22.0 and is now target for 31.100.0, the date of this update is yet to be confirmed but as soon as it is I will re-post.
BT TV ExpertDarrenW
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Niko1
Message 23 of 32
I've been living with this bug for a YEAR now, and the fix was promised in the recent update. Now we are back to square one with no confirmed release date? Come on..
Niko1
Message 24 of 32
Still waiting for an answer...
BT TV Expert
BT TV Expert
Message 25 of 32
@Niko1,
I have sent you a private message.
BT TV ExpertDarrenW
Kudos”
Coffeehair
Message 26 of 32
Happened to me again this morning. 🤤
chrissheppy69
Message 27 of 32
Yep me too, 3x times in the last 2 weeks, I've been having problems for a year and currently on 31.28.0.
Can someone actually confirm when this will be fixed instead of burrying your heads in the sand and hoping we will go away ???
Please !!!!! No reply from by since beginning of July, come on guys, what the heck is going on, I pay £22 pm for this trash !!!
BT TV Expert
BT TV Expert
Message 28 of 32
Hi All,
Yes there is a fix coming for the UHD box hopefully by the end of this month, the software version to look out for is 31.106.0
The version is currently in Alpha trial, we are just making sure it is safe to give to customers.
BT TV ExpertDarrenW
Kudos”
chrissheppy69
Message 29 of 32
It takes a year ? FFS !
Niko1
Message 30 of 32
I'm starting to believe that there is no fix and we are being fobbed off. There is no way it should take this long to fix a pretty critical fault.
