arthurbrown
Message 1 of 8
Re: Tv pro top box remote no volume
How do I get my remote to increase volume and turn tv off
7 REPLIES 7
NeilO
Moderator
Moderator
Message 2 of 8
Hi, @arthurbrown Welcome to the community, thanks for posting. The remote should automatically pair with the BT TV box and programme itself to control your TV. Can you try these steps if that hasn't happened?
  1. Press the Home and 9 buttons at the same time
  2. Hold down the buttons until the LED around the BT icon flashes purple three times
Post back and let me know how you get on.
Neil
arthurbrown
Message 3 of 8
No that doesn’t work by inform me I have too wait for a new download as my tv is too new bought it February this year.
DarrenDev
BT Sport Expert
Message 4 of 8
Is your BT TV Pro box connected directly to your TV with HDMI @arthurbrown ?  If it's connected via any other equipment (e.g. an amp, or switch), it needs to be temporarily connected directly to configure the remote.
Updates to the remote control map are expected to be very infrequent - manufacturers generally use the same codes even for newer models.
gspearson
Expert
Message 5 of 8
I often see advice to wait for three purple flashes.  It would be helpful to know if this means it might flash other colours - if it is just purple that is possible, there is no need to mention the colour.  I'm colour blind so what most readers here  call purple appears to me to be blue.  My TV remote is even worse - it has 4 colour buttons which, apart from blue, are all the same.
The problem has been recognised in the new cable colours: blue is neutral, earth is striped and live is the other one.
arthurbrown
Message 6 of 8
My tv and top box are connected by HDMI so do I have to reset everything, I can’t remember seeing anything about sync my remote on setup
DarrenDev
BT Sport Expert
Message 7 of 8
If your TV and BT TV box are connected directly via HDMI and they were when you followed @NeilO 's instructions, then I'm afraid there's nothing further that can be done - your TV cannot be controlled with the BT TV Pro Box remote. You'll need to continue using your TV remote.
arthurbrown
Message 8 of 8
That is not what I was told on my order enquirers and also you instructions refer to the tv box controlling your tv, without any reference to your tv ,model or age don’t is advertising and selling a product that is not as advertised.
