BT TV Expert
BT TV Expert
Message 2 of 6
Re: Unable to access BT TV Player
Hi marlenna16w,
I can't see any errors on the backend which are for the same situation as lothianman.
Please send me your account details in a private message and I'll take a look.
Steve
5 REPLIES 5
marlenna16w
Message 1 of 6
Hi,
I've got exactly same problem, would you like to hepl me too, please?
thanks
Marlena
marlenna16w
Message 3 of 6
did you get it?
BT TV Expert
BT TV Expert
Message 4 of 6
Yes thanks.
I can see the problem but need to pin down where the data incorrect in order to fix it. 🙂
I'll get the tech team to have a look this evening for you and come back.
Steve
marlenna16w
Message 5 of 6
Thank you very much
Marlena
marlenna16w
Message 6 of 6
BT TV is working now Smiley Happy thank you very much for your help
Best wishes,
Marlena
