Jennia
Message 11 of 13
Re: YouView - Players and BT Sport not working
Hi Paddy thanks for calling earlier today. I have done a 'software reset' and a 'soft' box reset without deleting my recordings. This has appears to have fixed the issue. My BT player is now working as well as my BT sports channels. Looks like the Youview software update did a little bit more than just updating...
Moderator
Moderator
Message 12 of 13
Thanks for letting us now it's all sorted @Jennia. Appreciate you taking time to do that. I'll pass your comments on to @PaddyB.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Dclark29385
Newbie
Message 13 of 13
Hi there, how do you do a  'software reset' and a 'soft' box reset? My box has not been the same since the upgrade and have the same issues.
