Message 1 of 3
Re: Youview box can't connect to internet
Hi, My Youview Box will not connect to the Internet, I have done all the Factory resets etc but still it will not connect. It’s a DTR 2100. Fortunately I have a spare box, I swopped the boxes and the spare one worked straight away.
Obviously an issue with the original box but a problem I have not heard of before.
Any advice would be very welcome
Thanks for looking
2 REPLIES 2
Message 2 of 3
Hi @Shimmy Thanks for posting, I'm sorry to see your Youview box has stopped connecting to the internet. It does sound like your box has developed a fault if it still won't connect after a factory reset. Do you currently have a BT TV subscription as we should be able to get a replacement out if you do?
Neil
Message 3 of 3
Hi Neil
Thanks for your quick reply, I don’t have a subscription now so will have to use my other Box pity because it’s been a great recorded.
Best
clifford
