2tabbycats
Newbie
Message 1 of 2
Re: youview recordings stopping after 2 minutes
Hi, the same thing is happening to me. Last week only 27 mins of Poldark and last night only 1 min!
Also The Fall this week 41 mins. Seems to be BBC giving me problems.
1 REPLY 1
JoeeeeeeR
Message 2 of 2
Hi there, I found the same thing happening to me a couple of years ago. I eventually discovered that the problem was my aerial, which didn't have a very good signal and kept losing signal for a few seconds on some channels. Irritatingly, this made any recordings I had set up stop. Might be worth checking if the same thing is happening to you?
