ToonArmy123
Message 1 of 4
Recent BTTV Vip package order
Hi,
New TV package activated today and I received the box in the post, however this box seems to be a standard box instead of a 4k box which I assumed I would get because of the 4k sports package.
Is this a mistake or do you not get a 4k box with this package? Seems a bit pointless if you don't get a box that allows you to play the channel...
Cheers.
3 REPLIES 3
NigelB72
Recognised Expert
Message 2 of 4
Re: Recent BTTV Vip package order
It depends on your broadband line speed
ToonArmy123
Message 3 of 4
Ah I see.
I had a 4k box last time I had BTTV so I assumed I would get the same again. A shame as I have a 4k TV so it always looks a bit blurry I guess when it's self to 1080p. Upscaled 4k gives it a better image
NigelB72
Recognised Expert
Message 4 of 4
They were giving the 4K boxes out freely a couple of years ago but they seem to be sticking to line speed at the mo. Tbh I only use ours for linear channels and use a Roku stick for streaming Including BT Sport Ultimate because of the lack of HDR compatibility on the box.
