Bib1
Message 1 of 6
Record from external source
Can these YouView boxes record from an external source - eg thru their scart or phono?
5 REPLIES 5
drhowells
Recognised Expert
Message 2 of 6
Re: Record from external source
Simple answer is no.
gomezz
Recognised Expert
Message 3 of 6
No. Which is the same as any other PVR. OTOH there are HDD/DVD recorders which do let you do this but they tend to only have a single tuner.
Bib1
Message 4 of 6
Thanks for the reply. I'm trying to replace a failing HDD/DVD recorder.
Trouble is, I can't find any current models that record from an external source.
Please tell me if you spot any otherwise it's 2nd hand only.
gspearson
Expert
Message 5 of 6
Sony RDR-HXD870 - DVD Recorder With 160GB Hard Drive - With Freeview - Black from teh shop named after a big river.
Bib1
Message 6 of 6
Thanks for the reply but it's only gonna be 2nd hand - presumably discontinued like all the other DVD/HDD recorders.
