donmaico
Message 1 of 20
Recorded BT sport pixelating badly
Hi , I only acquired the Youview box about two months and although everything I watch that is live and all recorded TV aerial programmes are absolutely fine , recorded BT sport programmes pixelate very badly right throughout the recording. Does anyone have any suggestions? Thanks
19 REPLIES 19
donmaico
Message 2 of 20
Re: Recorded BT sport pixelating badly
it now appears to be pixelating on live BT programmes as well
TimCurtis
Guru
Message 3 of 20
@donmaico
How is the Youview box connected to your router? Hardwired or powerline adapters?
donmaico
Message 4 of 20
one of those BT Homehubs which are both adaptors and have WIFI capabilty
donmaico
Message 5 of 20
i believe they are called broadband extenders
Hunter2660
Recognised Expert
Message 6 of 20
If you have one of the new Pro boxes, see if your box has the latest software, and if so ditch the extenders and connect via wi-fi.
TimCurtis
Guru
Message 7 of 20
@donmaico
The advice above should work if it's a Pro box otherwise try resetting the devices.
But just to clarify your setup.
Do you have 2 of these extenders , 1 connected to the SmartHub and 1 connected to the Youview box OR are you using the wifi capability of the extender and have just the 1 by the Youview box with it connected by an ethernet cable so essentially having the Youview box connected to the SmartHub by wifi.
donmaico
Message 8 of 20
How can I tell if its a Pro box  or not? I wasn't offered one so I assume it isnt
donmaico
Message 9 of 20
i have two, one connected to the router and the other to the Youview box
donmaico
Message 10 of 20
actually, I just checked pictures of each and i would say mine is definitely the standard recordable Youview box
