jam2000
Expert
Message 1 of 9
Recording 4 shows and watch a 5th
So now Humax have launched the FVP-5000T which can record 4 shows and watch a 5th, how long will it be before BT launch a new box with the same recording function?
8 REPLIES 8
gomezz
Recognised Expert
Message 2 of 9
Re: Recording 4 shows and watch a 5th
I can already do that. Though I do have standard Freeview PVR and Freesat PVR plumbed in as well as my BT Youview box. 🙂
srpsrp
Expert
Message 3 of 9
Me too, freesat is a slightly better picture, I also have a USB disk on my TV 🙂
jam2000
Expert
Message 4 of 9
That's with two boxes though. I have read several reviews and reports that freesat had a slightly worse picture than freeview
srpsrp
Expert
Message 5 of 9
Nope, freesat has higher data rate I believe. Consistently better on BBC channels at least.
Hometruths
Message 6 of 9
I have to agree, the picture quality on freesat is superior to freeview.
jam2000
Expert
Message 7 of 9
Is it sd and HD channels? Anyone have the two bitrates?
Hometruths
Message 8 of 9
I stand to be corrected but i believe bitrates vary from channel to channel on both platforms.
srpsrp
Expert
Message 9 of 9
It also depends on how many channels are crammed into a multiplex as well though,  the actual channels are variable bitrate since static pictures will use less.
I guess it depends on the size of your TV and how much of a geek you are etc etc  as to whether you notice the difference. It's not that big but for show case stuff like Blueplanet it does seem better to me.
(waiting for someone to come along and prove me wrong now 🙂  )
