moofydoofy
Message 1 of 5
Recording BT Sport
Suddenly unable to record BT Sport programmes. The guide will allow me to set the recording, however nothing actually records and no programme information/title shows on MyTV recordings list.
If I watch the BT Sport programme as it is broadcast, I am able to record it without any problems...
All other channels are wotring perfectly and can be set to record successfully.
4 REPLIES 4
gomezz
Recognised Expert
Message 2 of 5
Re: Recording BT Sport
First thing to try is a simple reboot by pressing and holding the power button until the load splash screen appears.
Moderator
Moderator
Message 3 of 5
Hi @moofydoofy Did you try the reset as suggested? If so did it work or are you still experiencing this issue? Post back and let us know.
Cheers
John
moofydoofy
Message 4 of 5
Have just tried the reset and it appears to be working ok (I had unplugged/rebooted just about everything else yesterday, just hadn't pressed that little power button! Doh!) Fingers crossed it is still working next time I want to record the rugby!
Thanks for the suggestion.
Moderator
Moderator
Message 5 of 5
Hi @moofydoofy Thanks for posting back and hopefully the Rugby should record OK for you.
cheers
John
