sea2dog
Message 1 of 12
Recording Question
I have the Humax youview box, when I go to the guide and hit on a programme on STV HD which is channel 103 then I hit on the R record button it will say record series or record episode, if I chose to record the series the programme records as it should, but what also records is the STV+1 version so I end up with two recorded versions of the same programme, only difference being first one is HD and the other is SD.
How can I fix this so when a series is recorded only the channel that is selected should be recorded and not the STV+1 SD version?
Tags (1)
11 REPLIES 11
Holgate001
Message 2 of 12
Re: Recording Question
I don’t think you can. Your BT box does similar stupid things. We often end up with two recordings. We just live with it and delete them.
sea2dog
Message 3 of 12
Thanks.
Do you ever get sound dropouts when viewing LIVE subscription channels, the ones that come via broadband rather than the aerial?
Holgate001
Message 4 of 12
We don’t get any sound problems with our box when watching any programmes.
sea2dog
Message 5 of 12
Do you view the non freeview channels live though?
gomezz
Recognised Expert
Message 6 of 12
Contact the broadcaster (STV) and ask them to sort out their use of CRIDs.
Holgate001
Message 7 of 12
Yes, mainly BT Sports and Eurosport viewed via broadband.
sea2dog
Message 8 of 12
@Holgate001
I take it that you have a Humax box and BT Hub?
Holgate001
Message 9 of 12
Hi We have a BT Youview box which is a Humax DTRT2100 box and a BT Hub.
sea2dog
Message 10 of 12
@Holgate001
May I ask which BB speed package you use?
