MF123
Message 1 of 2
Recording alerts
Hi,
When a recording starts on the BT box, it brings up an alert pane at the top irrespective of what else is on the screen e.g. if you’re watching another programme. It stays for several seconds and then disappears, but it’s there only to inform you that it’s started recording. It’s incredibly irritating but I can’t find a way to disable these notifications.
I would be grateful for advice on how to do this.
Many thanks!
1 REPLY 1
TimCurtis
Recognised Expert
Message 2 of 2
Re: Recording alerts
No way to switch it off I'm afraid. On the old software this wasn't so intrusive , by a long way.  That's progress - NOT.
