youviewbunny
Message 1 of 2
Recording and the Hub
Do I need the Home Hub on to record non-HD TV programs on my YouView+ Box.?. How do I turn the Hub to standby?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: Recording and the Hub
If you're talking about the normal Freeview programmes delivered through the aerial, then the YouView box will work whether or not it's connected to a Home Hub.  the hub is only required for the extra channels streamed over the broadband.  Those obviously do need the hub.
the Home Hub doesn't have a standby button, as it's intended to be left on all the time in case you want to use it.  You can program it to go into a lower power mode at night, on a timer.  Go into the Hub settings http://bthomehub.home/ to enable that.  Low power mode turns off the wireless, but any wired connections are still on.
