kaybal
Newbie
Message 1 of 3
Recording problem
Why do some of my recordings stop before the end of the programme - very annoying
2 REPLIES 2
Andy005
Message 2 of 3
Re: Recording problem
Hi @kaybal, It's a combination of poor software from Youview and broadcasters that can't stick accurately to their schedules. My experience is that the UK broadcasters are better, AMC for example often overruns its schedules.
TimCurtis
Recognised Expert
Message 3 of 3
That'll be because Youview insist on using Accurate Recording for their start & stop times with NO padding. AR relies on a signal from the particular channel you're recording to start the recording & then another signal indicating the start of the next program for when to stop the recording.It's because the broadcaster gets the timing of these signals wrong that you can miss either a bit at the start and/or some at the end.
