Message 1 of 6
Recordings are not letting me fast forward or skip
Hi , I am trying to work out why I cannot Skip or fastfwd on my recordings .Tried to skip through MOTD this morning , skip just sends screen blank then says press and hold to resume but nothing  so just watching motd from beginning .it’s on all my other recordings ,I have switched off box at mains and restarted but still the same won’t skip or fast forward just a blank screen . Thks
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Recordings are not letting me fast forward or skip
@Carl6789 sorry about that it sounds like a pain, did you manage to get this sorted?
Message 3 of 6
No still not working , other older programs work but this is brand new recording and scree goes blank
Moderator
Moderator
Message 4 of 6
@Carl6789 Can you try a reset on the Youview box ensuring that you keep the recordings to see if that helps?
Message 5 of 6
Thankyou so much !! That has worked all recordings saved and skip function works on all recordings , Cheers again
Moderator
Moderator
Message 6 of 6
Hi @Carl6789,
Thank you for posting back. I'm happy that's worked you Smiley Happy
Cheers
PaddyB
