Murphy3
Message 1 of 3
Recordings distorted
Pick have not had any problems with Youview since joining. However over the past few days my recordings are subject to intermittent distortion which makes it impossible to view. Eventually corrects itself but missing key bits of recordings. Any advice appreciated. I am have Infinity.
2 REPLIES 2
Murphy3
Message 2 of 3
Re: Recordings distorted
Should read "I have not had any problems...." & "I have Infinity" **bleep** predictive text!
Distinguished Guru
Message 3 of 3
Oh I know the problem well!
It possibly without more details to go on sounds like a signal strength problem.
ie an aerial issue or a transmitter issue, it would be worth checking out locally if there is transmitter work going on and visually checking your aerial and then checking the connections to the actual box.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
