PJ_Maybe
Message 1 of 6
Recordings picture freezing on playback
My Freeview reception is very good and I do not suffer from pixilation or picture freezing while watching live TV.
However on several recordings I have made I get picture freezing (not pixilation) that takes quite a few seconds (20 ish) to clear.  Rewinding and replaying gives the same issue.
As I am deleting recordings after watching I have started to wonder whether there could be an issue with the Youview box's hard drive (i.e. I am recording programmes over the same bad sectors of the disc).
Is this possible?
Are there any hidden disc utilities to check the hard drive?
5 REPLIES 5
Moderator-Retired
Message 2 of 6
Re: Recordings picture freezing on playback
PJ_Maybe,
Did you manage to get to the bottom of this or are you still having trouble?
Chris
BT Mod Team
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
bpalmf
Message 3 of 6
Did you get anywhere with this? I'm having same issue.
PJ_Maybe
Message 4 of 6
Still happens sometimes.
matt4001
Message 5 of 6
I have the same problem.
bpalmf
Message 6 of 6
Hi
I've jsut swiched it off at the back and restated and all seems to be fine now. Worth a try!!
