Having received my YouView box I wondered if it is possible to transfer my recordings from BT vision box the YouView box.
Solved! Go to Solution.
The simple answer is "no". The Vision box isn't designed to allow you to transfer off recordings. The only ways I know of to get recordings off are:
A "get around" is to run both boxes together, providing that you have enough HDMI sockets on your TV.
