Trivialis
Message 1 of 4
Recordings transfer
Having received my YouView box I wondered if it is possible to transfer my recordings from BT vision box the YouView box.
Distinguished Guru
Message 2 of 4
Re: Recordings transfer
The simple answer is "no".  The Vision box isn't designed to allow you to transfer off recordings.  The only ways I know of to get recordings off are:
  • Play each program in turn, recording it via a SCART lead to a VCR, DVD recorder or similar.
  • Take the disk out.  But even then the recording format is non-standard.
Trivialis
Message 3 of 4
Thought not but worth a try. Thanks
davidb00
Message 4 of 4
A "get around" is to run both boxes together, providing that you have enough HDMI sockets on your TV.
